Here is the meat & potatoes of my TR's build-up which has recently gone a new best 1/4 mile of 11.43 @ 119.6 mph w/a 1.62 60 ft. (10lbs of boost footbrake launch & 23~24 lbs of boost through the traps.) Still messing around with a street chip & xylene homebrew so 10.8's should be realistic once I step it up to a race chip & C16.
CPP Competition shortblock: stock block, new stock crank, CPP spec 206 cam, 9:1 forged pistons (Venolia), billet caps on the centers, Race Jace engine girdle and everything smoothed, balanced & blueprinted
Stock heads freshened up with new springs etc... & 3 angle valve job
Ported stock intake & modded doghouse w/ 65mm throttle body
50# injectors (w/ matching CPP street chip burned for my combo)
TE-61 turbo w/ PTE .63 exhaust housing
Terry Houston downpipe into a 2 1/2" hooker exhaust
Action Fab "stretch" intercooler
S&B air filter / homemade cold-air kit flowing into a solid MAF pipe
HR PartsNStuff poly driver's side motor mount
Mike Kurtz built tranny w/ 3200 rpm 9/11" converter
Stock 3.42 w/ 28 spline Moser axles & c-clip eliminators
HR PartsNStuff lower & upper rear control arms
Mickey T, 28-10.5-15" slicks
What is the stall rpm on your converter?? The te-61 is VERY streetable on my car, spools faster than the stocker ever did & will hit max boost about 2/3 of the way through your average 4 lane intersection!
Doug C.
