Bruce Urie
The Ventures,CCR forever!
- Dec 30, 2006
That's funny. I messed with liquid nitrogen all sorts of ways in science class, and it never did what it seemed to do in the movies. I tried freezing all sorts of stuff with it.. it got no colder than if I left it on my porch for a day. (in 9 degree weather). I'd like to see him try and break cable that thick with liquid nitrogen...
Though, I could be thru that cable in NO time, with a battery powered cut off wheel and a tow truck. As the guy was slipping those little adjustable frames under your front wheels, I'd be sawing the cable. It would take literally no longer than 60 seconds to make your car disappear. And lojack.. heheheh. Even a rudimentary knowledge of radio and/or microwaves will tell you there's several ways to defeat the lojack system.
The only way is to keep your eye on it, or to box it in with a few other cars...
You're right...the best way is to keep an eye on it. And box it in. But in public that is impossible most of the time. Un, you can cut through 1 1/2 inches of CASE HARDENED cable? What would you about the four wheel brake lock system that I don't tell anyone about (now I am) that I kept under the hood with a rounded key (like they use in vending machines) to unlock the brakes? And the ignition shutoff system on it? And the missing steering wheel? The teakwood wheel is only attatched by 6 machine screws and I took it off with me any time I was away from the Vette for more than 1/2 hour. How would you defeat the four locked brakes while cutting the cable and putting the front wheels on dollys?
The liquid nitrogen boils at -321 degrees F at atmospheric pressure. It's kept in vacuum flasks to keep the low temperature at -321 degrees by slow boiling off to gas. It's only good for a few weeks or hours. I saw a rubber ball dipped in a flask of liquid nitrogen then dropped on the floor...it shattered like glass. Then a stem with a rose on it was dipped, dropped and it shattered like glass. Are you sure you weren't using cold Koolaid in class?:tongue:
I can't mention the other anti-theft things I did to it, there are more, and this is from a guy who will go to any length to keep his car, no matter what. The new system I'm coming up with, I can't share. The more that know, the more chances of it being defeated. I don't want to give anyone any time at all to figure out how to defeat it. Suprises is the owner's best friend...never prepare a thief by revealing certian methods. The point I was making is, the more you make a thief take time to get your car, the more chance you have of him quitting. Soon, it'll take me about one hour to unlock/undo everything on the Grand National, so that means it'll take a pro thief about 10 minutes to do it.
Mark, that was funny!
Bruce '87 Grand National
