blackbuick87
Senior Member
- Mar 11, 2002
Was screwing around under the hood and found an unplugged connector coming out of the main harness running along the drivers side valve cover, right behind the alternator.
It has two pale yellow (tan?) wires on one side of the connector, which is green, and the other side has one gray (white?) wire going into its side of the connector, which is black.
When i connected it the only thing that happened is my factory tach stopped working
The car seemed to run the same.
Any ideas or is this something the previous owner rigged?
