SignUp Now!Quick6'n'-K.C. said:Make sure all your wastegate hoses are fresh.
Does the car have a adjustable wastegate rod, and is the spike only down low?
Does the boost finally creep up to a higher pressure the faster MPH you go?
BW
Razor said:The MAP sensor has nothing with controlling/regulating boost.
72firebird said:correct me if I'm wrong, but I thought the MAP read the pressure and conrtolled the boost solenoid with how much air it is releasing out the other opening on it. Does the WG solenoid read the pressure also for it's own control?
Razor said:The only thing you probably messed up will be the hoses going to the WG actuator.
Boost is almost completely controlled by the two hoses/Y/ and WG solenoid. So any breach in the air traveling from compressor to WG will creat higher boost.
Do this, run a hose straight from the compressor to the wastegate, this will setup your minimum boost. If this brings the boost down.. reattach hoses.. Next is plug the open hole on the WG solenoid thats on the valve cover... this should yield the same results.. If this works, check your "Y" and wastegate solenoid.
remember the "Y" has an orfice on one of its legs... the leg with the orfice goes to the wastegate.
Report back..
