Motor specs.
Bored 30 over DLS internal balanced crank with stock rods. TRW pistons, seal power rings, new water pump, casper cam sensor, factory oil pan.HR Parts soild motor mounts.
Stock heads, with 110lb springs lightly ported. Cometic headgaskets. Billet center main caps, DLS bearings, Ported by Champion stock intake, PTE plenum, 83lbs injectors, no a/c parts.
with 70mm Accufab T-body, Double roller timing chain, Comp cam 484-488 -216-218 flat tappet, manley push rods, rhoades lifters. No prblems 100 passes on the rebuild. Building a stage2 motor and none of these parts will interchange. Turn key ready to run!! Make offer?
