boostingbuick
Going to be buried in this.
- Aug 25, 2002
SignUp Now!boostingbuick said:Any help would be great. They appear to be stronger or larger than a two dot and will bolt into a stock production crank.
boostingbuick said:These pics may help. No other marks that i can tell. And these are full floating .927 pin and are stock length. Had them in a 87 prod. block.
SPEEDSTAR said:Those are the fordged BMS rods sold with the stage 11 block, heads ,and crank during the eighties,, part#25500007 , fordged 4340 steel, 3/8 aircraft quality through bolt and nut, .927 dia. pin, described in the Buick Stage11 V6 Performance Guide.....Jeff
boostingbuick said:Thank you all. But how much power can these things handle? I want to make a solid 600 to the tires.
