What Kind Of Trans Fluid In your Turbo Buick?
RussellinNC
Car lover!!!!!!!!!!!
OK.....What kind of Trans Fluid does everyone run in their Turbo Buick 200 Trans? What type of abuse and use does your car see?
In my other cars/trucks with a 400 Turbo Trans I always run Havoline Type F.
Russ:cool:
Mobil 1 Synthetic, with 8 ounces of Lucas additive each change...in all the equipment.
HTH :)
I've been wondering this too. If I get a convertor before my engine goes back in then I want to switch out to type f. I'm using the regular Dexron III right now. The type f is supposed to make it shift a little firmer and decrease the temps slightly.
Amsoil super shift trans fluid mixed with Amsoil hydraulic oil. Works fine although expensive.
Hydraulic tractor fluid.. I forget what the name of it is but it's Bruces' secret stuff and you can search the archives for it..:cool:
Discount auto parts F fluid...........239,000 original miles.
WORKS FINE, ALTHOUGH CHEAP !!! :p
Are there any downsides to type F? does it run cooler or hotter in the trans? i want to switch, but my main concern is temperature and longevity(i cant really afford a rebuild anytime in the near future)
TIA
Type F will make it shift a lot harder, I have it in my car, but if I were trying to not ruin the tranny, I would put TrickShift in.
When my 200 wears out, i'll just buy a 700 :D
Mobile 424 Tractor Fluid. :cool: Plus a couple of quarts of Dextron for color (so that I can read the dipstick). ;)
Meant in a nice way but, why would you do a dopey thing like that? :confused:
We run a Chevron tractor hydralic with D-3 in all our units and like the results. But as you can see, everyone has a slightly different idea about the fluid. It all comes down to the same reason you chose a GN over another type of car, it's all personal choice. Most important thing is change your fluid and filter often and make sure everything is kept clean. Mark :D
hey danster ,after listening to each side of dark side of the moon ten times lol.
LMAO Chris. After that experience I didn't leave my house for 10 days back when that album first came out. Too funny man. I saw that avatar and my first though was an eclipse. lol,,,,, Mark:D
