this is the vidoe of the surge
You may be correct, but my other 87 I had with just a te 60 turbo and front mount with 42lb injectors when 11:70, this one has GN1 ported and polished heads cam, eagle crank, Eagle rods, aftermarket headers, alky injection, ect. Alott more than I had in my other GN and I can tell you from driving it that it is alott faster than my 11 sec GN. I have been 8:90s in my Dodge so I do know a little about what it feels like.
But now I have a problem I cant figure out. The car feels like it is surging in first gear. It will rev up to about 4000 when you floor it and the boost goes to 15lbs. After it shifts the boost goes to 21lbs and it flat ass hauls ass. 2nd and third gear will hold you in the seat while it is tearing the tires apart. But I cant under stand the 1st gear thing. No Knock and the alky system comes on at 8 psi of boost. What could be the cause? Before we put the converter in it it would just make one pop at the 1st gear change. Now it will surge at 15psi and no knock and only 4K rpms. Once it shifts it is a rocket and runs great. and the rpms climb just like they should.
I have a video of it surging at 4k. It doesn't want to climb higher than 4 k in first but will run right in all other gears. It has tt 5.7 chip for alky in it. Car is set at 21psi for street use.
