Well guys...I still have no start on my rebuilt motor.
Checked SES light - bulb was removed - put back in and I get code 12 over and over. No other codes flash (after having rolled it over a few times). I have checked and double checked the Cam sensor and crank sensor - all set corrrectly. I have spark and gas but no start. Compression is good - its a rebuilt motor. I also checked all the grounds as well. The coil and module are brand new - so are the crank and cam sensors.
I get 1 extra RPM light on my gauge when I roll it over - does this mean the crank sensor is working ? What would you guys try next ? ECM bad ?
Help.... TIA
