what size hole is needed
DIAZ 87
2-1 FOR 2010
what size hole do i need to make in order to install the LED light on my 2 Gauge Console Pod
Do you mean for Alky? Just get a drill index and get the bit thats a lil smaller and go
Thanks guys,i was able to drill the hole,and yes it was for the alky low level sensor
K . But I must say thats different typically teh 2 color LED is on the pods and the low fuel which is in the low fuel light on teh idiot lights.
U have a different dash?
Per instruction.DR BOOST im trying my best:rolleyes:
Well...us normal people put it in the "low fuel" idiot light spot. But some of us have over 60,000 miles on and can void our warranty from GM...:biggrin:. I hope you have it done today....
The LED's that come with the kit are both the same size. The low level and the power injection "bulb" have an additional rubber grommet to allow them to hold in those factory slots. If you wish to install the LED in another location, then dont use the rubber grommet.
Some guys have GNX style aftermarket dashes and dont have the "Low Fuel" bezel.. on this applications the LED has to go somewhere else. Just like you dont have to use the "Power Injection Bulb". Its a not needed item for the system to function. As its just a small bulb wired across the pump wires.
I too use a unibit. 15/64-1/4 inch is fine.
i ended up finishing up the installation this morning:biggrin:as far as the LED lights,i install them on my 2 Gauge Console Pod,I just figured since im Puerto Rican im going to do the opposite then what the normal person would do:eek:Also ended up going to DR BOOST house to have him look over the install.
He went to get an opinion from Dr Boost :eek::D
Inside joke ;)
this is where i installed both of my LED light,sorry for the mess but haven't had time to clean up:o
I put an alky kit on for a guy earlier this week. It was one of Razor's newest kit and works great as usual. He too is now hooked. He brought the car to me on "E". Filled it up with 93 and meth. TT chip adjustment, well over 20psi and no knock at all!:cool:
Diaz- How much boost are you running? Time for a 35psi gauge too!
Not Avg 6- I still haven't seen the new T-Type...:(
I have mine set at 23lb with zero knock but i still need to tune her alittle more and raise the boost 2 to 3 more lbs;).Sh!t your right about that time for a new boost gauge:eek:
How is the car feeling to you? Im sure the street tires are useless now. M/T DRs for next year?
:rolleyes:Lets just say my buddy with the GTR is and will be pushing the what the f@ck botton some time this month:biggrin:as far as having drag radial tire's,that was taken care of many years ago.my drag radials i have only have about 300 or so street miles on them but like always the only way to know how fast she really is i need some track time;)Buick 022 - TurboBuick.Com GalleryIm hoping for a mid or high 11's
Maybe if you, Viper04, Brer Rabbit, No Avg6, and TurboBuRick, get ready we can all go to Da Grove and get some tuning time. The goal is to see if we can get kicked out for no cages!:D
