toomanymodz
- Oct 14, 2009
Well, I just installed a new WB 02 sensor to see where my A/F ratios are. Under WOT, the A/F's were around 11.6 to 12.0, which is a little on the lean side for sure. My injector duty cycles were between 94% and 99%. (Yikes! I know!). I'm running 23# of boost with 110 leaded fuel. I'm getting a small amount of retard (around 2.5 degrees). So I decided to see if I could add a little fuel to richen it up a bit. I moved the Max Effort thumbwheel from position C to position D to add WOT fuel. This helped the A/F's a little, putting it at 11.4 to 11.7, but my injector duty cycle worsened and hit as high as 102.2% (never knew it could exceed 100 percent). Knock retard got a little worse and hit 3.2 degrees. I would like to see A/F's between 10.9 and 11.3, but there is no way these injectors can do that.
I'm running a stock shortblock, stock cam. Ported irons, PTE-51 turbo, stock MAF, huge FM intercooler, Vig 3200 LU converter and 009 (43#) injectors. The previous owner has ran a best of 11.27 with this combo and the car ran 11.30's-11.40's all day long. I'm not sure how he got away with this for so long.
It's obvious that I am out of injector. I'm debating whether to go with 50#, 55, or 60s. Thoughts?
