What temp of the engine ?
TurboTdr3.8
What temp should the engine be before using the alky system , what is the lowest to use it at and what temp seems to work the best .
IMO once you see the oil psi drop to normal ops level from being fully warmed is when you are good to go.
Goes into closed loop. 150+ degree's. Same as temp before you go and flog on motor. :D
