What to expect??
missin' 2
I just bought a te 60 and 65# injectors from precision. i have an alky kit and im wondering what stall i should use?(2800-3200). what times should i expect?
2800 will work.
Times will depend on how hard you push it. Big difference between 20# of boost and 30# of boost.
what would change if i were to go with a 3200. would it spool faster or just be unecessary
It would definatly spool faster, but may come with an overly "slippery" feel.
As Dusty said, a 2800 would be very nice.
te 60
I have a 3500 stall in my car.I have an .82 exhaust housing on mine.spools as fast as a stock turbo,really drives about like stock.I ran 11.03,and 11.06 at 26 lbs. of boost @ 121.9x mph.I have stock bottom end,stock heads that I ported,009s and alky.Good luck.......
Quick 6 in KC went a loooooooooow 11 seconds on his turbo and some 009's I believe
Is this what it was rated at when you bought it or is this what rpm your seeing at 0# of boost? A true 3500 won't feel anything like a stock converter.
I went 11.25@121.9mph on a 1.77 60ft time. That's at 23psi and 23/21 timing. I know she'll go in the 10's with a better 60 time. I hope to do that in the spring.
i have no idea what 60' time my car will get. im not planning on racing it but just want to do some tt at the track. i have a 70 gs with stock suspension and bfg drag radials. not expecting much but i know i can improve the suspension.
missing 2,my take is you should get a quality converter non lock or lockup your choice around 9-10.5inch, i prefer the 3200 stall personally.like others have said how fast is dependant on how hard you push things and what risks you are willing to take.
