What turbo?
This is mostly what I know since I just bought it. It has 3” single cat back to duals. Still has cat but idk if it’s gutted because there’s a receipt for the cat a couple years ago. He ran it on 93 it has great power, from a 10 mph roll it blows the tires away through 2nd gear the stall seems to be a 3k. Everything seems to work well, I’m changing to e85 because I only have 91 locally and everything I’m reading it makes sense to change from a power standpoint and less worrying about detonation. It may need a spring cleaning I’m not sure if anything has been done in that regard. Thank you for your help!
I would look at what kind of boost the car is actually seeing where the afŕ is at if it's a wide band o2
If your seeing narrowing o2 numbers like off a scan master you will want them 770/800 mv at wot.
Make sure you see o degrees of knock retard.
  • Like
Reactions: qak
Also don't this the wrong way but that isn't showing me much in terms of combo
Just the intended tune of 93 and 18 psi.
Which with some upgrades will require better fuel volume to support more boost and power.
The converter trans and you being able to tune it there can be very challenging.
On 93 and low boost you should not hurt it.
If you choose to want more boost and power then raising boost better octane changing plugs adding fuel to target afr that is needed and adjusting timing will be needed.
Basically if the guy had 28k in mods the car was tuned up and you received a low boost but modded car.
He didn't give you the car with it turned up.
Looks like $28k including the car to me
thank you, its 17-18 ill have to check the other numbers. Im still figuring out how to use the scanmaster
Idk it's pretty vague
it is vague, im kind of a newby here just trying to figure it out. Ive had friends with these in the 90s and one with a new typhoon but i never knew much about them and proper setups. I appreciate the help, ill take all constructive criticism. In the end i want this thing right even though ill have some missteps along the way
I would say drive the car with the 91 and 18 lb and just learn the car. Spend the summer driving and reading ,do the spring cleaning you'll learn a lot there.
the parts you have order won't go bad in the box.You need to find out all the mods that have been done, and not from hearsay, but actual hands on.
just looking at the pic. it appears to be a half hazard hack job that after 2 years previous owner can to the conclusion he was over his head.
It only took the previous owner of my car 6 months (Previous owns before him had it 5 years garage keep) and it took me only 1 year to drive over the crankshaft in 2010. Three years and 2 rebuild later I have started having good results.O you don't want to know how much this has cost me.. Wish it was just 28K. Ive rambled
