SignUp Now!Originally posted by turbodan1
Was real curious why the cam was wearing into the front of the block????..and how this could happen... I am actually having this problem with my motor, and my combo is alot like yours..... So any HELP would be greatly appreciated......
Sorry if I miss your thread up at all..........
Ya Im not sure how to fixes this problem either, and I really dont fully understand how this could happen..... It has a brand new stock front cover, with a high volume pump in it..... the guy I bought the cam from said it was be/c the cam had to much end play... its is a roller set up 214/214..... he said that I need to shim the cam button to tighten up the end play, and it wont hit the block no more..... but my biggest question is.... what is suppose to stop the cam from hitting the front of the motor, if I shim the button...it seems like it would push the cam further back towards the block???
Thank You for your help...Turbo1dr
Originally posted by Turbo1dr
Very true EightSecV6. Even if you do put a roller thrust between the block and the cam you still have the oil pump drive gears wearing out from turning a HV pump.
Originally posted by EightSecV6
I have not found that to be the case
If I'm reading it properly, what you're saying is the roller thrust washer takes away enough friction from the cam rubbing the front of the block to virtually get rid of oil pump drive gear wear?
I thought about that and that doesn't seem possible since you're not getting rid of the thrust that the oil pump is putting on the two gears of the cam/cam sensor. Instead, it's just eliminating the wear that occurs at the front of the block that the HV pump puts on it.
Originally posted by 49-blues
Bill- what do you consider "loose" clearances? By the way i believe im gonna have you do my next short block rebuild. thanks
As a solution, I am pondering the thought of grafting the lower part of a 86-87 front wheel drive timing cover and oil pump to the upper section of the regular Turbo Regal front cover. This will get rid of the stress that a HV pump puts on the cam sensor gears and eliminate thrust on the cam towards the block. This way, the crank is turning the oil pump which is taking stress away from the timing chain having to turn all this stuff.
May be easier said then done!
TURBOGTA1 said:ALMOST DONE, ANY DAY NOW!!!!!!!!
