SignUp Now!What E.T. and/or trap speed do you think an engine with ARP main studs, diamond pistons, and ARP rod bolts handle? (In a TTA that's dropped some weight. I think it's around 3,2xx pounds.
I'm assuming the weak link is the caps getting cracked.
depends on your tuning abilitys.
a few stock blocks have turned numbers in the 10s...
whats your skill level?
A.j.
138-140mph in the quarter for a while if there is no detonation.
Skill level... OK I guess. Turn it up a little at a time and keep the 02 millivolts in the high 700's then repeat. I keep the timing pretty conservative. From what I've seen the guys running fast on stock rotating assemblies are not using a lot of timing on pump gas/ alcohol. Seems like the faster pump gas cars are only using at or slightly more than 20*s in 3rd gear.
At 26#s of boost I'm not seeing any knock with what I believe to be ~ 20% of fueling through the alcohol kit and 02 recall on scanmaster showing 790mv
(chip fuel trim is for 16#, so absolute pressure there would be 30.7# I added 7% through chip, so that should provide gas fuel for 32.8# absolute... 26#s of boost would be 40.7# absolute, so I've got ~8 pounds of fueling from alcohol)
By-guess and by-golly numbers give me the assumption that the engine should be making about 700 hp at the crank with 26 pounds.
The motor has diamond pistons, so I'm not too worried there. Hey, I guess it doesn't take a genius to turn up the alcohol kit if it starts getting some knock.
As far as timing goes. From what I've seen the fastest pump gas/ alcohol car with a stock crank and rods claimed to be running 20* with an E.T. of 9.62
...........I'm assuming the weak link is the caps getting cracked.
I have seen a 12 sec. GN grenade a stock block at mid-run.
Destroyed the block, crank and other parts including the trans.
Pushing a 25 year old stock short block at any level is a crap shoot - metal parts are subject to fatigue, especially the cast crank.
That's the bad part of cast iron. It's either in good shape, or it explodes. There's no bending one part and not ruining anything else.
I'm just not going to run it too hard. I don't have the time to start building another motor right now, and I've never even had this one to the track with a good tire. I really don't know how much further I'd try to go with the TTA. Once you go into the 9's the heads, downpipe, intercooler issues become more work than it's worth on a TTA, but then again I've already addressed a lot of the problems like the rear end and some other stuff.
The car picked up a ton of power after I made this sucker and that was a typical problem area for a TTA
This going in the car was also a bonus!
If I were getting into turbo Buicks again I would have gotten a T-type.
Shoot for 9.60. That would be a tough oneI don't know if any stock block TTA has gone 9's, but it wouldn't be a huge accomplishment anymore.
