What wires are u using with the TR6??
Also known as mine.. yaa
Here are my custom made wires. Moroso ultra 40 s. Also note the ignition module on the driver's side inner fender.
Did you make those yourself?
tonysmach-
That motor looks spectacular. Nicely done sir.
Thank you. I relocated some of the vacuum lines to a vacuum block on the firewall to give it a cleaner look. The PCV and FPR vacuum lines are tapped into the 1 inch plenum spacer. I need to replace my heater core which is why I have it bypassed.
