What would you do?
Which Flat Tappet Hyd Lifter with Comp cam & Springs?
  • Comp Hyd Lifter - Matching manufacturer
    Votes: 3 25.0%
  • GM Hyd Lifter - Still the best available
    Votes: 7 58.3%
  • Johns Performance - Does not matter who makes it
    Votes: 2 16.7%
  • Total voters
    12
Jerryl
Tall Unvaccinated Chinese Guy
Fresh motor, Comp cam & springs.
Which flat tappet hyd lifter?
Answer is NONE. 210/210 billet roller. Or they all will wipe out and destroy your bearings and crank in time Then you will cry, why didn't i go roller and be out the $1000 to rebuild the motor the 2nd time. Iv'e been there. the choice is yours
i'll have to 2nd norbs. roller cam is the only way to go. if your cam come's apart it will cost you more in the long run. and you will have better performance with a roller.
