SignUp Now!If you want a higher boost lauch a transbrake is your best bet. Turbo/convertor plays hugely into this as well
That is the common upgrade to put on the Syclones & Typhoons.
I have them & they work great,have not done any damage to the backing plates & our vehicles have the weak a$$ 7.1/4 IIRC rear ends.
What year S-10 wheel cylinders do you use? and is there any step by step directions on the install? thanks in advance.
Yes.....trans needs to be able to handle the abuse.
As stated the higher boost "power brake" launches whether with Pro valve and big cyl, big cyl and stock setup, etc, etc will tweak the backing plates. With 10 plus psi launches.
