What's good for brake dust
DJLATIN
Classics & G-Bodies
off of these wheels? I've tried several products and nothing works.
Oreillys Eagle One MAG WHEEL CLEANER. This is for etching mag wheels without the clear coat finish.
Not the all wheels cleaner.
Mag wheel cleaner and a plastic hand brush will make them look new again, you cant just spray it off, you have to work to get them clean if they are that bad.
BW :)
I tried the eagle one cleaner but i guess i should have put more elbow grease and it was getting late. Thanks, I'll try that out again this weekend with more sunlight.
appreciate the fast response,
gabriel
napa has a spray call aluminum brightener that will make them like new
Don't use AL brightener if they have the factory finish on the it will turn them yellow.
I bought a set that looked like that it took bead blasting to clean them up.
