whats it worth, and what is this???
Jdsluckybu
GBFL
ok so guy want to trade me my truck for an 85 chev truck i have. well i decided to keep my bagged truck and he may still trade for my malibu/ i have a feeling no mater whats done to the bu, an 85 hot air gn will still be worth more
so this 85 has 120k, 300mi on rebuild. ported and polished heads, new turbo
2300?? stall. (probably cam and injectors) guys only had it for a year but he was telling me it runs real rich and has a dial that has 5 settings on it, plus a valet setting the higher the number the more smoke (rich) it runs<--- what is that?? i have a feeling its an old school add on programmer or something
are they junk?
do most modded gn blow smoke (fuel) when modded
my malibu/
long list
1979 malibu grandma tan with tan interior
355- 11:1 forged 010 4 bolt trw pistons
studs top to bottom
afr 210s
crower 1.5
crane girdle
super vic
bg 750 with purdy reg plate
lun solid 248@50 .555
lun solid roller lifters
dbl roller chain comp
pink rods
4340 eagle crank
fluid street damp
6qt pan
all an filter relocate with sleeves
march serp alt, wp, ps
weiand alu water pump
new ps pump and gear box
msd dist, wires, 6al, blaster 2
brand new front end with tube roundy round upper control arm
b body (big) upper ball joints
new calipers and brake hoses
moroso front trick springs
th400 tci converter, reverse man, and brake
stock rebuild (clutches) old band
32elm tci sprag
an w/ push lock trans lines to large cooler with own fan
$100.00 worth royal purple trans fluid
tci alu pan
stock drive shaft
1x1 3/16 square fabricated cross memeber with poly motor mounts and trans mount
68 cougar 9in with stock third member
det locker, strange 4.10
moser axles 5/8 3'' studs
3'' hats with .810 rotors
roundy round metric weld in caliper mounts with new calipers and hoses
wagner thermo quiet pads front and rear with pad spacers in rear
2x4 rear frame with 2x4 rear where bumper mounts
poly body mounts
flush 15gal plastic cell in stainless bucket with alu top
steel raised trunk floor
opt batt in trunk
2g welding leads to remote sol
steel fab ac delete rivited
steel rear firewall and back deck
alu side panels
8 pt cage welded to floor with 6x6 plates
por 15 cage, rear fire wall, and deck deck
newer rear springs
edl lower control arms
edl upp adj with del bushing
poly housing bushings
-8 push lock cell to holly black knock off fuel pump
to engine, bg y block 1 for no2 other for carb
new log style knock off fuel filter
por 15 trunk
gen 6 nx kit 50-300 plate 100
2 bottles, pills, heater, gauge@ bottle and sol
purge kit
auto m comp 2 5/8 fuel pressure gauge under harwood 4in cowl
autometer phantom 5 in tach shift light
oil and water 2 5/8
alu rad
electric fans
controler
much more
0mi on mickey thomp dr 275s
vw front tires
grant wheel with tb button on
jimmy jams wot bracket and switch
skummit buckets with covers
black 5 pt harnesses
pro stick
shoenfield 3.5 flomaster reduc to 3in
3in 2 chambers flows dumps
band clamp collectors
best on motor 11.82 almost 114
361 hp na
461 hp on 100 shot
no time on no2
1 dyno pass was the only time no2 has been hit hard
never raced with the gas
short test burst on street
everything is less that 2yrs old
maybe 100mi on street
about 15 passes na
this is a nice car and still has some minor things that need to be done
body no rust
any way what do you guys think? whats the 85 worth? still 5-7k???
