whats needed for powerlogger
QUIP'6'
Brian Roman
i am very interested in getting a powerlogger and need to know all the items i need. i have a scanmaster and i know i need the 6.0 chip from eric and the powerlogger. what do i need to get as far as a wideband? do i need just the sensor and the wire. thinking of the plx
So you don't NEED anything to run the powerlogger. YOu just need the powerlogger. Now if you want to do thing like log WB02 you need the sensor and controller and if you want to use one of Eric's 6.0 chips you need PL, WB02 and min of 50lb injectors.
You need a Laptop go to
//www.fullthrottletech.com/index.php
check out requirements to run PL if you want to stay on top get a comp better than minimum specs
the sensor and the widebands brainbox.
thanks guys i was wondering if you just needed the sensor and wire and just hook it up to the powerlogger or if you need to hook the sensor to the brainbox then to the powerlogger. i do have a laptop
Is it a big deal to install the powerlogger into a driver modded ECM ???
I currently have the powerlogger in a stock ECM... but will be switching to 83lb injectors and modded ECM soon. Just wondered if it was difficult to swap over.
Nope... Just as simple as it was for the stock one you have.
