whats the fastest.........
Cleaner13
The Cleaner
ok I am sure this has been beaten to death
but what is the quickest 1/4 mile time on a GN or turbo regal that only has bolt ons and new heads
nothing in the engine like pistons or cam
it can have an upgrade turbo and intercooler and everthing I am just wondering what the fastest has been thus far
I dont plan on opening the engine at any point, I however just bought a complete set of stage 2 heads and I have the following bolt ons
Gauges boost, temp, oil, tach, knock, air fuel, fuel pressure
RJC Powerplate
92Thrasher chip
THDP with cutout and dump
Duttweiler Neck
Engine Tie Down
ash tray Switch Plate torque converter, fan relay, fuel pump
Pinion Snubber
Volt Booster
Big Mouth Intake
B& M Tranny Cooler
160* Thermostat
Racetronix plug and play with fuel pump
Driveshaft Loop
Adjustable Fuel Pressure Regulator
Scan Master
2 pod Console Pillar
Hooker Exhaust or the dual atr exhaust
HRPartsNstuff lower and upper control arms
Upgraded Crossover Pipes
Aluminum Pulley
CAS Radiator
Jay Jackson Throttle body and Plenum port and polish upgrade
Ramchargers Boost Controller
GTA Black Honeycomb wheels
recalibrated 145MPH Speedo
Eibach lowering spring kit
Shocks what kind should I get?
3 Pod A-Pillar Lotek
Rear Seat Brace Kit
Shift Kit
SMC alky kit
future plans for upgraded injectors and turbo at some point
thanks alot guys
my friend talked to a guy who said he has run a 10.88 on DR's on untouched valve covers!!! dont know if this is the fastest but its pretty damn quick for a stock engine!
my crank rods pistons and block are stock ...127 mph so far looking for 130+ in next 2 weeks..:)
