F
faststkr
Guest
I know that the higher the pressure the better the fuel atomizes with the air. Problem is I have a dual nozzle alky kit and I want to be able to pump in more alky so I can raise my boost more but I'm running rich when I turn the pump speed up so now I've turned the static pressure way down and alky up. So whats the lowest static pressure you can go and still have the injector spray properly?
Harry at Precision Turbo said there is no low limit
