What’s the next step up
T- Type Tim
Vice Chairman
What is the next step up offered from turbonetics from this turbo :
I would recommend you call Jack and talk to him direct, if you're looking for Turbonetics turbo info.
With their shift in performance direction earlier this year, Jack should be able to get an exact answer.
Technically in T-netics world, the 60-1 would be next. IE: 60 compressor wheel, with the P-trim turbine wheel. Then the 62mm series, but Jack can get you sorted out with T-netics turbos.
What are you goals?
If you are considering turbos other than Tubonetics, I picked up my 6262 from Bison yesterday.
It has a 4" inlet and is replacing my Precision TE60.
Might want to give him a call.
That’s a nice looking piece
I’m going to stick with turbonetics
And the external gate on the compressor housing
