R
SignUp Now!Originally posted by timothydog
Do you hear any "popping" or detonation?
Sounds like you need a scan-tool to give you some readings and tell you what's up.
Another thing, is your car stock or what? Give us some specs.
Cuz if you are stock and going 20-25lbs boost you are in for trouble.
Originally posted by SilverSleeper
Has it thrown any codes?
You really need to get the compression checked. It sounds like it might have blown a hg and is crossfiring between cylinders. How is the idle, is it stubling or rough?
How do the plugs you pulled out look?
Tell us about the car..
stock? modded? how many miles?
While it is running, take a screwdriver and tap the MAF sensor (black plastic tube thingy by the air filter) carefully, dont beat on it. If it stumbles, a new MAF is likely in your future. Similar thing happened to me a week or 2 ago. Is it a solid pipe up to the turbo or a "dryer hose" ? Check it for leaks on the turbo side of the MAF.
You may have to test the coil pack as well. But, you should do certain tests to eliminate things one by one, or you will be chasing this all over the place.
1st thing. check your compression. If all cylinders read ok, then we can eliminate a hg. A blown hg alone could be causing all of this. running 25#'s on a stock car, you can bet a good amount that it has happened.
DOnt count on white smoke to indicate a blown hg.
My van ran really bad, but no white smoke, no coolant in the oil either. SUre enough when the head came off it was blown between 3 and 5. No indication other than the low compression on those 2 cylinders.
Im still trying to figure out how you hit 25#s of boost in the first place. Stock cars usually cant do that. Stock turbo maxes out at 24#s if youre lucky, and modded.
Check to see if your check engine lite comes on when you turn the key on, make sure it isnt blown. You definately want to know if it is throwing codes.
Just the fact you even got to 25#'s tells me the car has been modded. It might have a bigger turbo, better exhaust and other things.
