I have 4 GTA fronts all around, but the rears rub a little bit on turns. I would also like them to sit out a little bit further. Question is, is it safe to run spacers on teh rear with stock lugs? If so, how big? TIA
the NHRA rulebook says that the threaded part of the stud has to stick into the hex part of the nut by the diameter of the stud- so a 12mm stud would have to stick 12mm into the hex part of the nut.
this seems like a good rule to follow.
pull one lug nut off and see how much stud sticks out past the wheel, then subtract the thickness of the spacer you want to run and see if it is still long enough.
also, check to see how much of the center hub is sticking out past the drum- the wheel centers off this hub and it actually holds most of the weight of the car.
I had to use a 1/4" spacer with 275/60 15 DR and I didn't feel safe with the about of thread engagment that I had. I got longer ARP studs and don't have to worry about it. Cheap insurance.
