SignUp Now!Newbie here....about how many horsepower does it take to get the front wheels off the ground?
Not much really. I do it all the time with my 2.5 ton floor jack. I give it about 5 good grunts and they both come up. They stay up too.Newbie here....about how many horsepower does it take to get the front wheels off the ground?
wheelies only slow down your forward momentum. instead of pushing the car forward, your pushing it up. properly dialed in suspension will not wheelstand near as high as slop suspension. What are you looking for? cool factor?
Lets do the math:
Ex. 3000lb car that has 50/50 wt. distribution and produces 400 ft. lb. of torque. The car has a Powerglide with a 1.82 low gear and a 4.88 rear gear.Torque multiplying factor is 2:1 (normal for a stock converter). Center of gravity is 19" and the whee base is 108"
Will the car wheel stand? First find the Drive Wheel Torque:
1) DWT= (engine torque x converter multiplication x first gear ratio x rear gear ratio x .85 (accounts for friction loss))
400ft lbs. x 2.0 x 1.82 x 4.88 x .85 = 6039.488 ft lbs (lets call it 6040)
2) Need to now know drive wheel thrust: wt.= DWT/TRR (total rolling radius)
The car has a 32" tall tire so we take half the diameter 16/12 = 1.33ft
wt= 6040ft lbs./1.33ft. = 4541.35 lbs. So we have 4541.35 lbs. of force pushing the car off the line.
3) G-force applied= WT/car wt. G-force = 4541lbs./3000lbs. (Car wt.) = 1.51G's
4) Longitudinal wt transfer =
Vehicle wt. x Center of Gravity height x G Force/wheel base
3000lbs x 19 inches x 1.51G's/108WB = 796.94
So now we know that we have 798.94 lbs. of weight transfer from the front to the back; the car is 3000 lbs and has a 50/50 wt. distribution which is 1500 lbs on the front. With a weight transfer of 796.94 lbs we can predict this car will not wheel stand. I learned this at a Dave Morgan suspension class.
Jeff (I definitely have too much time on my hands. I need a 12 step program immediately)
