Wheel/Tire Gallery Thread -- submit yours!
BlackMetal
In an effort to stop the constant flood of "who's running 18's" and "post up your aftermarket wheels threads" let's try to get a gallery going.
Please provide a picture or two at most and as many details about the size/spacing/tires as possible. You can PM me and I'll edit it into the gallery or post here and I'll copy the information, PMs would result in a cleaner thread.
Will attempt to organize as:
Stock wheels with bigger tires
15" Aftermarket
16" A/M
17" A/M
18" A/M
19" and above
Staggered fitment (two different wheel sizes)
Jegs / Summit Brand rims, 15x4 front, 15x8 rear
Coys Polished C5's
17x8, 4" Backspace, Fronts, 245/45R17 Tire
18x9.5, 5" Backspace, Rears, 275/40R18 Tire (alum drums, no other mods)
Stock GN Rims-Fronts 235/60/15's
Rears 275/50/15's
TT II's.
15x8 w/275/60-15 rear 3.75" bs
15x6 w/215/70-15 front 3.25" bs
Just your 'normal' Welds. 15x8 rears, 15x5 fronts with 225/60/15's front and 27x10.5x15 Hoosier Quick Time Pro's rear. I like the 'look' though......
Here's a few shots I took today. Front tires are 215/65/15 (stock size). Rears are 275/60/15 MT DRs. Front rims are stock. Rears are stockers that were widened to 8" with a 4 1/8" back space. Springs are 1" lower at all four corners. With a 28" tall tire out back, it brought the back end back up to stock hight, but with a big tire tucked under. Also, gives the car a very slight rake, without looking "stink-bug". Shocks are Bilsteins. had to grind 3/16" off the iner fender lip. Also, have airbags at about 9 psi. Have more pics if needed.
Happy spooling...
Mike Barnard
Centerline Autodrags-Fronts are 15 X 3.5's with 205/75/15's...Rears are 15 X 8.5's with 275/60/15's...BS on the rears is 3 7/8's
American Racing Trak Star's...
Rear...15x8 w/ 4" bs... 275/60's
Front...15X4 w/ 1.75" bs...26x7.5's
Suspension Mod's...Rear Coil Pigtails removed...Front 2" drop spindles
Front are 15x4 weld vitesse r/t series (brand new)
Rear are 15x8 weld vitesse r/t series with 4.5 b.s. with 1/8 spacer
front tires are m/t et front 26x4x15
rear tires are m/t street radials 275/60/15
man I ove the way that car sits.......Did you cut your inner lip and you dont run wheel well trim right?
Thanks...Inner lip is cut back to clear sidewall. I still have the wheel well trim, it was cut also...John
CENTERLINE CONVO-PROS
REAR: 15 x 10 5in B.S. 325x50x15
FRONT: 15 x 5 Frt
Eagle Alloy "Style 212" 18/20 combo with Toyo tires
- 18x8 and 245/40/18 up front
- 20x9.5 and 275/35/20 out back
17x8f 17x9r TTII
shotty pics, but show the lips well
Here is an ok pic for redemption
This is the idea for the future. Matte black wheels. Probably 18's, definitely with an aggressive stance.
Nick
17x8f 17x9r TTII
Nick
looks good but please dont paint the caliper pink!!!!!!!:redface:
