Wheel valve stem size
Sal Lubrano
Woke up to a flat tire this morning. Just want make sure I purchase the correct valve stem. Is the factory size a TR413?
Thank you
Yes correct, is the valve stem damaged, rubber or metal, or does the stem need tighten? Good thing about it, your flat occurred at home.
So old dry rot. Make you laugh. I went to the others and gave them a push, then that tire went flat. I have broken beads on other cars to change tpms sensors at home. Not a big deal. We all get old and rubber does too. Thank you for the confirmation.
That is old , may be the original stems, I had my car for 33 years , and probably have change my stems 4 times. Do you run nitrogen in tires.
19 years it's definitely time for new ones, just curious I been running nitrogen 10 years or so me personally the ride is so much better. I run nitrogen in all of my vehicles .
