I agree with Nick. A well known engine dude that most of us would know said the same thing Nick said. Maybe he'll reply.
I've never met Nick, but I've been around here from the beginning and EVERYTHING he's said has always seemed to be right on target. He knows his ****e!!!
I personally have 146,000 + miles and it revs over 5,000 rpm in a snap. According to DirectScan it shifts at 5200. I've used a synthetic oil since the car was new, so maybe that's kept the oil from overheating and causing some type of thermal metal spring fatigue?
Has anyone dynoed or checked out 1/4 mi. mph as to how much hp you would lose at 5,000 rpm with say a TA49 or TE 44 before and after spring change at say...22 lbs of boost?
I wouldn't think it would be over......15-20 hp at most?? And if you can run 22lbs of boost on the street even with a stock turbo, you're going to be kicking major ass, on most cars that are out there. I doubt that another 20 hp is going to help on the street. Unless you have some real nasty meats, you'd lose it in traction anyway.
I think we've all been there. NO FLAMES. These are just my OPINIONS.
I know a guy who changed springs...I think they were 100 pounders and wiped the stock cam. And I don't think he was using a synthetic oil. So, maybe it has to do with what kind of care and treatment the engine has been through. Like the kind of OIL?
I think I'll wait until I tear the engine down. I don't want to create any problems. Oh, I run a TE44 and even with Z rated tires, on most street surfaces, I can hear a little chirping all the way through second and a little into third. If I had more hp I don't know how I could get from point A to B without doing a bunch of suspension work or street slicks. I have the typical rear...boxed and bagged.
I just thought of this. What do you think is the max. hp you can run on the street, with street tires...just a good vr or z rated tire...
and still have TRACTION....350 hp? A little spinning would be okay! Maybe that should determine whether a guy needs a spring change or not!
