KILL4PEACEUSMC
Team Infidel
- May 7, 2007
I wonder were or even if someone is reproducing front timing covers. I called my local GM dealer and was told they quit making them in 95. Thanks
SignUp Now!I wonder were or even if someone is reproducing front timing covers. I called my local GM dealer and was told they quit making them in 95. Thanks
Heck Yea! Thanks!
I wish I would have bought one a few weeks ago, got one coming now, thanks for the info! I just got done with my short bock and Im a little disipointed with the oil psi, and my cover was looking sad. I checked the gear to adapter twice, its good. Hope the cover does the trick. All the cam and crank bearings were installed with no issues. 20lbs at idle.
Aftermarket timing covers are VERY poor quality. The last one I purchased had the main feed gallery COMPLETLY blocked off. They hadn't drilled the hole. They must have missed a step in the build process. I really didn't care, though, as I do a TON of work to any timing cover before I install them, anyway. All the oil passages need to be radiused. The oil pump clearances are usually way too loose, too. I tend to put about 2-3 hours into a timing cover to get things right. I set the oil pump thrust clearance to .0005"-.0015" max. TA Performance sells pump shims to help you set it up right. If you don't want to tackle it yourself, drop me a PM, and I'll see if I can fit you in. Before you start grinding on the timing cover, be sure to check the cam sensor alignment. I, too, had a aftermarket timing cover with the alignment bad and when the engine first started up, it sent aluminum shavings through the brand new engine. The side load on the cam sensor was so bad that it spun the lower bushing in the sensor and sent all the aluminum "dust" through the engine. I though I had lost a cam bearing. So I pulled the engine and tore it down only to find that the bearings were all like brand new. It took a bit of investigating to find the bad sensor, and figure out why it went bad. That cheap timing cover cost me thousands of dollars in labor. Check those things out CAREFULLY! Some guys are lucky and they work fine. The last one I bought lined up good, but had the passage "issues".
