Where can I buy just a trans filter, and not a filter AND pan gasket together?
Geoff87
Administrator
Staff member
Looking for a 700 filter or a 4L60 filter, to use with a deep pan. -They're the same, right? :confused:
Also, does anyone know where I can get the flat, unfolded type of pan gaskets?
Geoff, try calling trans- parts express or something like that, the one by farmers market. They should have what you need.
593-0100
Geoff.
yup, gaskets came in a flat, envelope-type package but the fiter may have an extension of sorts on it, since it should still reach the bottom of the pan.
Rob
Anyone know if the 4L60 and the 700 are basically the same filter?:confused:
Geoff,
If they have the stock pan, yes, I believe so.
I kind of recall different part numbers for '99 and up, though...
Rob
Hey Geoff I called my friend at Redline and its around $18 for the 700 filter and gasket if you're going to buy the filter its comes with the gasket but only the gasket you can buy seperate not the filter.
Trans Parts Express on Ahui St.
Just wanted to add, that I bought a gasket for the 200-4R (the good, flat unfolded type) and a 700 filter (deep Art-Carr pan) for only $13~.
Thanks for the tip John!
