Apr 3, 2006 #1 F Fab Shop Member Joined May 17, 2005 Messages 37 Where Can I get a On Center front high volume timing cover. Thanks Jake The_Fab_Shop@comcast.net
Apr 3, 2006 #2 M Mac in SD Active Member Joined Jan 20, 2002 Messages 2,905 Fab Shop said: Where Can I get a On Center front high volume timing cover. Thanks Jake The_Fab_Shop@comcast.net Click to expand... You can't. You have to either: 1. Mill .120-.125 off the gasket surface of a stock (or hi-volume) front cover, and mill the accessory bracket too, or... 2. Use a stock cover and space the balancer/hub out .120/.125. (Watch your distributor/cam sensor - to- cam gear alignment with this method.) HTH.
