Bob Avellar
- May 25, 2001
I thought I repaired my engine harness to the starter (fusable links and start wire to the solenoid). When I did this for some reason I used small ring terminals to connect to one of the small posts on the starter solenoid. At the time i thought that the only wire that connected to the large post on the starter was the battery cable. When I connected the fusable links to the R terminal at the starter there was no power at this terminal. My solenoid has an R and S terminal plus the big post. In order to get power to the links i had to jumper the large post to the R terminal and I don't remember having to have a jumper there before. Maybe I used small ring terminals because I was looking at a regular Regal harness or something- not sure. I can't say I remember the links being connected to the large post but after searching the BB I am under the impression that all the fusable links connect to the Main large post along with the battery cable and the start wire goes to the S terminal. Evidently no connections are made to the R terminal on the soenoid. This is not an original starter/solenoid and it has an R and S terminal.
How many terminals are supposed to be on an original starter/ solenoid and where do they connect? I tend to forget what went where when the process of restoring the GN takes 1 1/2 yrs.
