SignUp Now!You can find the y-vacuum line connectors at any autoparts store such as oreilly's, autozone, etc.
They aren't special order and aren't expensive.
You mentioned a wire connector, where did you see mention of that?
It would be best to come around underneath the header so you don't melt the wire sheaths.I moved the ground wire to the front of the passenger side head. Is this correct?
Better ,not long enough to go under the header ?where dose the other cable go,one to battery , one to chassis ?
Did you find the post on you wast gate pluming? And get it sirted out
with that external (ATR) wastegate, you should probably not hook up the solenoid. just leave it the way it is for now.
you need a hose running from the turbo to the wastegate with no other doodads, and see if the wastegate is controlling boost.
any decent engine bolt is ok for the battery ground.
Do you have a boost gauge? The factory dash gauge is not very accurate.
You need to make sure your boost stays under control, i.e. under 20 psi, as we continue troubleshooting.
Bob
Lol. Sure Isnt. HELP. What do I need to hookup and/or missingBet your speedo isn't working?
It's the speedo cable there's another half there somewhere
It's hard to see in the picture but it looks like the other halfWhat is that cable under the master cylinder?
