Do any of our vendors carry them? The one on my turbo now is ported a little larger than I would like for the wastegate. Also are all 3-bolt .63's the same as far as bolting up, or is each turbo brand specific? Thanks.
All you need is a plate from RJC that goes between the housing and downpipe. The hole is small in the plate and can be opened up exactly as you need regardless of the hole int he exhaust housing. It will save you a lot of time and $ and can be used with any stock style 3 bolt exhaust housing unlike the housing itself which is specific to the turbine trim. Its like the one in the link below but it has a hole for the wastegate that you can open up to any size you want. Call him because i dont see it on the site. Down Pipes'n Parts
