Where to find seals for the Racetronix double pumper fitting?
22lbChevelle
Does anyone know what seals should be used in the racetronix double pumper fitting? I purchased the red anodized fitting and its missing the seals. I'm assuming these use viton o-rings. I have some that work for the inlets but I wanted to make sure it uses an oring on the outlet before I spend much more time looking into it.
Did you contact our order dept about this first? The o-rings depend on the pumps and fittings being used.
I sure did, I was told they would send some out but those haven't been received. I contacted again and they said they would look into it.No one ever asked what pumps and sender I was using. I bought the fitting as a stand alone so maybe that told them what seals I would need?
So does anyone know the answer or can anyone confirm that the outlet uses an oring for the seal?
SI-113862
O-rings were sent out via small packet-air mail last time you conversed with our order dept.
Standard o-rings would be the same as used on OUR DP sender.
