Racetronix 340 Pump, Senders, Bottles, Flowkool water pump, Fuel Regs, Tail light tri, and misc
trick86
Solid Member
Hello all,
Just finished cleaning out the last corner of the garage and this is the last batch of stuff modds. Larger items ship for around $25, smaller items can go from around $10. Motivated to cut 10% deals when guys buy multiple items and will be more than fair on shipping. paypal plus 3%. Professionally packaged and shipped via USPS Thanks.
-Racetronix 340 pump, 2000 miles use, just removed and shot both ends with WD-40 for preservation, upgraded to double pumper last week - $50
-Flowkool water pump, maybe 1000 miles, engine black 9/10, upgraded to TA, - $75
-NEW GM AC Delco analog sender 10/10 25092745, - $150
-original 86/87' sender, 8/10 - $50
-NEW NOS coolant tank with line.... years back these where not available for a period, think I paided $125..... 10/10, on the block for - $55
- pair of lightly used coolant and washer bottles, - $40
-Kirbans silver fuel reg, not a scratch on it10/10, - $50
-older blue anodized adjustable reg, missing some hardware but worked when last used, shows some wear 7/10, - $30
-stock front engine fuel lines, just removed from my car last week and known good, WD-40 pres, shot with cast grey 8/10 - $50 pair
-Kirban's passenger side upper control arm bushing heat shield, with nut on lock washer 9/10, - $15
-original 86 license plate holder, 9.5/10, - $10
-2 passenger side tail light trims, no cracks, nice and completely restorable 7/10, - $50 pair
339890
339891
339892
339893
339894
339895
339896
339897
339898
339899
ok ill try again with different card just put into paypal pump and blue reg again never did this before so bear with me
ok i think last time i used paypal 15 years ago i had to send you some info or the other way around ,how things have changed
Paypal can be a pain every once in a while.... especially when one wants to lock down a purchase.
I will take both of these. What is your paypal
The Kirban reg is sold but the heat shield is still available. I'll PM you.
The heat shield, Flowkool water pump and lightly used washer bottle are sold. Lightly used coolant bottle still available for $25
