TURBOELKY
- Jun 27, 2005
and this guy better have put that scanmaster on by now, it only takes 5 minutes
SignUp Now!and this guy better have put that scanmaster on by now, it only takes 5 minutes![]()
OK...Scanmaster is now installed.
It was a litte scary at first cuz I installed it upside down...but I was able to figure it out on my own ... quickly flipped it over and all is good.
I have not powered back up yet as I'm going under the car and installing the hotwire now.
Stay tuned...
Stay tuned...
Leaving the wrapper on a battery doesn't allow it to vent properly.
When you get everything else installed and some fresh gas is in it, replace your o2 sensor. Bad gas and fuel additives (five across the eyes again) will kill an o2 sensor and make it too slow to respond. Made a huge difference when I first bought my car. I actually have a "new gas" and an "old gas" 02 sensor. Put the old one in when I park it for the winter and use it for periodic starts and for that first tank of 5 month old gas in the spring. I used to just put a new one in every spring but now I think I will stretch it 2-3 years (3k miles). Other than that you are on the right track.
Yup. I installed a Walbro a couple weeks back.
Hotwire is in.
Car starys and idles fine.
Recheckeed the fuel pressure and it's at 43 hose off...38 hose on.
I'm gonna go driving to let the computer re-learn.
Tell me what you guys need to know from my ScanMaster.
Tim
Hotwire is in.
Tim
your bat is good
tps is perfect
it all looks good to me, but others i'm sure are better with exact explinations.
I think your running a little hot,
if your getting that much knock, you definately have an issue. your either over boosting, or there's something else going on. your o2's were ok at wot, so your getting fuel. I forgot, is your turbo stock or bigger than stock? maybe you need to check your wastegate, maybe its not opening. did you get that boost gauge on there yet? like in one of my posts to you, your probably over boosting. This reminds me of a dudes car I work on, here's the story.
if you need help, i'd gladly help get your car runing decent, but i'm a little drive out. You need to get somebody local to help you before your rebuilding that engine before you have fun with it. Or go drop it off with Lou! but if you dont have that boost gauge on there by the end of the week, were coming to get you![]()
KR = 0
AF = 05
L8 = 35-38
Bat = 13.6 (shouldn't this be higher?)
Int = 128
bl = 124
Clt = 187
Ats = 106
r = 825
Tps = .44 at idle and .42 with engine off. WOT engine off and floor mat out= 4.36
IAC = 37
cc = 163
nal = 00
Oh...Water temp = 200.
Thanks.
I'm pretty sure it's the stock turbo. Is there an easy way to confirm?
I'm thinking it has to have something to do with the tune in the TT chip. Here's why...
I had some knock/ping prior to the new fuel pump, but the new Walbro almost eliminated it.
Next thing I did was the 60lb injectors and TT chip. Then the knock/ping got worse than it ever had been.
Is it normal for the O2's to vary all over the place with periods of stability at the mromal mid-high 700's.
Next item to purchase is definitely the Boost gauge. I promise. Until then I'll keep my foot out of it and keep the KR at 0. After I get the gauge on there, I'll either take a couple of the locals up on their offers or be going over to see Lou. I just want to be sure I've got everything else in order before I make that 10 minute drive to go see him.
How do I tweak the TT chip?
Is this a laptop and software package thing that I need to get?
Is it possible for me to disconnect the WG? Will wathcing things at WOT with the WG disconnected tell me anything about my knock issue?
Howdy,
The Clt at 187 was after I had shut the engine down and let the fan run for a few....
When I first checked it after getting back and before shutting down, it was 200. It's a pretty cool night, so I'm surprised it gets this hot. My ZZ502 in my 68 Camaro only hits 180F....200-210F on a hot day.
It's most likely the stock thermostat, so when I order that boost gauge, I'll order the 160F stat also, and a FP gauge on an extension.
New TT chip with 60lb injectors, installed last week in place of the original 28lb injectors and a no name old school chip.
Thanks!
Tim
A Stock, TA-49, TA-60 and TA-61 all look close to the naked eye. There are guys on this site who can tell the difference. To me they all look the same.
KR is from too much boost and or low fuel delivery OR timing.
So your already running new 60lb injectors and a TT chip?
The TT chip can be adjusted through the Scan Master from what I have been told. I don't have a TT chip, I am currently running Lou's chip.
Next questions, did you get an alky or 100+ oct or race chip? What is the timing on the chip?
