Is this written on the chip label?
Should be, if not call Eric to confirm.
SignUp Now!Is this written on the chip label?
[/IMG]
See the little black cylinder contained in the red circle? thats your fuel pressure regulator. all gn's have a little black cylinder lookin thingy there. Whether or not its adjustable, depends on if the previous owner installed one. see the little screw contained within the yellow circle on top of the pressure reg.? if you dont have a screw there, yours isnt adjustable.
If theres no screw, put this on your christmas list. ALL buicks MUST have one. Thats not an option.
Mine's got a rubber hose attached to the end of it...
I guess I need to remove the hose and see?
BILLET ADJUSTABLE FUEL PRESSURE REG
List Price: $99.00
Item Code: 001BUREG
Weight: 1.00LB
Brands: FULL THROTTLE SPEED & STYLE
Categories: Buick Fuel Pressure Regs & Fuel Rails
Description
Buick Billet Adjustable FP Regulator
This all billet high flow adjustable regulator will handle all your fuel system upgrades. Rebildable! Easy to adjust fuel pressure up and down for maximum tuning. A must have item for all Turbo Buicks
Tim,
Remember, These are what I have been used to working on for the past twenty years.
So this was whole new ballgame for me as well but I got the bugs worked out with (spring cleaning)<--- term you see alot in ref to GN.org's page, So keep at it.
Get them Vac lines replaced.
Map is located on pass fender behind overflow, follow vac line.
I have adjustable wastegate asslembly for stock turbo I will send you if you want, But you still need Autometer boost gauge cause the pretty lights on dash are wrong and you could very well be overboosting as I read on a post in this thread
This time, I accelerated hard from about 5mph. The audible knock came in in first gear where it's usually the worst. The O2 mv was 750 at 18 mph when I got out of the throttle. The KR....0.
Now the stroange thing is that this was recorded during audible knock that was so bad that it sounded like someone was shaking a rattle can under my hood. Previous reads on this level of knock the KR was as high as 12.2. Could this be an indicator that my knock sensor is malf'd.
Tim
what is your beating of choice? here are your options:
brass knuckles
nun-chucks
baseball bat
sock w/20$ of quarters
or just a good ole belt?
let me know.........
What about 50 lashes with a Cat "O" Nine Tails?..Wait maybe thats what his wife will give him when she locates the secret GN money pit receipt stash hes got hiding behind his dresser drawer third from top
BTW: in the pic with the gift wrapped battery, whats that strap and eyebolt for? some sort of a motor mount??? prevent twisting?? or factory part??LOL
These Buick have a tendency to break motor mounts and that strap is just added insurance. Some may say it also prevents Knock I say BS on that.
