I must of ordered the wrong set, the wire part that holds the speaker did not line up at all. So I just used the adapter plate and zip tide them in place and it worked like a charm. The conversion plate is shaped so that when you zip tie it tight you just make sure its over the 6x10 stock hole. It actually looks super clean and the zip ties are run through the metal part of the speakers and the other side of the zip tie is in the actually slots that the OEM speaker holders go into.
on ebay the brand i bought was Best kits & harness, part #50012 while the adapter from 6x10 to 6x9 bolted up perfect, the hangers that hold it into place were incorrect. I like it better with zip ties.
