Changing valve springs soon and want to put in comp 980's. Went to the Summit web site and it seems there are two different types. CCA-980-12's and CCA-980-16's. Now I know one set comes w/ 12 springs and the other 16 but there are other differences listed in the description of each. Any help would be appreciated. Thanks!
CCA-980-12's - 1.230 in. O.D., .876 in. I.D., 308 lb. spring rate, single, valve spring set
CCA-980-16's - Single spring, 1.230 in. outer diameter with damper. .888 in. inside diameter, 322 spring rate, valve springs
