which chip and spark plug
I use a Translator setup with an Extender chip and AC CR43-TS plugs gapped at a tight 0.035". Any tighter than that and my cars sputter. Around 100-108 octane timing seems to work well (21-26 degrees depending on car and combo).
You are looking at $4-500 for an LT1 MAF, Trans Plus and Extender chip. A MaxEffort is a little less because you dont need the MAF, but still close to $400. If you dont mind not having total spark and fuel control contact Jim Testa or Jay Carter and have them burn you a custom alcohol chip for less than $100 probably
