Which Converter??
aquickv6
What is the strongest converter to run in a full weight TR with the 2004R? It's a low to mid 10 second car with future plans for a T-brake. 70 GTQ turbo and I would prefer to retain the lockup feature but not necessary if it will seriously compromise the converter life. Thanks for the advice!
I had great luck with a protorque convertor last year with basically the same setup, Chris from CK can get you in touch with one, THey have a pretty mean lockup unit, but i ran a non lockup
From most of the posts I have read in this section CK Performance is great to deal with and does top quality work. I will check with Chris to see his recommendation, as I would use his brake anyway. Thanks!
