Which headgaskets?
Hey Red,
Do you know what your cylinder pressures are on a compression test with your steel shim gaskets?? I went from 160 psi to 170 psi per cylinder when I went to steel shims??? Just checking because I am wondering how much my heads have been milled.
Thanks,
Tim
cant remember but cranking compression will change with camshaft also so unless we had the same cam it wont be really accurate
I am currently running COMETIC brand steel shim headgaskets with great sucess (high 10's) stock block. Put them on dry and go. More info (P/N Etc) email me.
Mitch
