RED LS1
SENIOR MEMBER
- Dec 31, 2001
Well my motor is going together. I previously had PTE 85's. I was going to run stock ECM and chip so I bought a set of Mototron 60's. I just now pulled the trigger on an XFI. So now the Low Z PTE 85's are an option again. They flow 76lbs at 80% duty according to PTE. So would you run the 60's or 85's?
Here is the rest of the combo.
fresh rebuilt 3.8 shortblock. Stock, cranks,rods and pistons. Deep BG oil pan. Comp 212/212 cam. Fresh stock heads with light port job and big valves. 65mm throttle body and plenum. Not sure what fuel pump yet. Will tune with XFI. Trans is all new built and converter will be 3200-3400 and Turbo is T-netics CPT-66 BB.
Goal is to run a 93 pump fuel and 20psi tune about 80% of the time on street and run a race gas 24-25psi tune a few times a season.
