Which intercooler with ALKY?
Dreamcar86
To all my ALKY friends out there.
To date the best mod I have ever made for my car is the ALKY Control. I am thinking about stepping it up a notch at this point. What would be the best intercooler option to complement the ALKY? I am looking at all options, i.e. front mount, stretch, stock location, dutt neck well you guys get the idea.
stock location although the Alky is really doin the cooling :eek: :p
With the cooling aside, is it important to push more air with a larger intercooler or should I just stick to the stock one until problems arise?
By the way, that was the fastest response I have ever received.
hey it was lunch time for me :D we have an old CAS V4 stock location .. worked fine (10.10 @ 132) .. Precisions, GBodyparts are just a few :cool:
You can't go wrong with Duttweiler neck for the money & will free up around 2 lbs of restricition in your stock intercooler. It's been working real good for me & i WAS running a BGC 23 row stretch intercooler on my car. On a mild 11 second combination with Alky i don't think there is much to be gained with an aftermarket intercooler over a Duttweiler necked stocker.
The price on the gbodyparts is very reasonable and it looks to be a quality piece. Thanks for the feedback Mr. Super Quick responder.
What heads are on your 10 second setup and for that matter what turbo and injectors?
ya BUT ya have to do some cutting and some don't want to do that .. most just want to bolt it in and forget it :cool:
yea cuting 3" into a replacable headlight bezzel thats cheap to replace is totally chopping up the car :rolleyes:
$1000 is what you'll need to even start a conversation about fm with the venders.
2 my cents
2 my cents
hmmmm... thought ya had to cut the rad support to ???? I don't have to worry about it though .. We have a crappy old V4 stock location that works fine :cool:
kevin , fyi , your V4 used to belong to grumpy , its a proven unit
Water to air
I've figured a way to have an unlimited supply of 80* water. Need to have a water to air intercooler with almost no restriction.
Anyone know where to find such an intercooler?
If it had no restriction.. then it couldnt cool.
Spearco has huge W/A IC's.
Big $$$$ tho :)
Have fun.
I picked up a 24 row dutt neck stock IC boxed and converted to water/air, a shurflo pump, 24x17x3 heat exchanger, and lines for $450 on the board awhile back! wicked cheap liquid IC setup!
