turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
I completely understand with higher than stock spring rates and more aggresive FT performance grinds but close to stock springs/grinds are fine.
SignUp Now!I completely understand with higher than stock spring rates and more aggresive FT performance grinds but close to stock springs/grinds are fine.
got to beat the horse agani and again
Just bought ZDDP, anyone mix 3 qts synthetic and 3 qts valv vr1 ??
I use Mobil 1 but I am considering switching over to standard 10W-30 unless there's a good reason i should stick with synthetic.
IF YOU HAVE SYNTHETIC NOW I HEARD THAT YOU CAN'T GO BACK TO NON SYNTHETIC OIL MAKE SURE OF THIS BEFORE YOU SWITCH OVER.
Would the same results come from a roller motor as well, you think?
turbojd said:I've been using Mobil 1 synthetic 10w-30 in my GN for the last 17 yrs. although I now add the zddp with oil changes.
