"if your running stock exhaust valves, it has a step built in that will tear up the valve seal if you have them installed on that side. Stock heads didn't have seals on the exhaust from the factory."
Russ Merrit"
I'm not sure what you mean, if you have installed an exhaust seal on a head, it will tear it up? But a stock exhaust valve with no seal will be ok?
just trying to learn
Ken
